Regardless of the code, there are many other "variables" that come into play.
Materials, Joints, Code requirements, company requirements, inspection and testing, documenting, reviewing and many more come into play. Each one of those can take different amounts of time. Mix those up with someone new to the process, and the time goes up.
Why do you ask?
Have a good day.
Gerald
A lot depends on the client and how soon they need the WPS.
I am bending a test set today, August 27th, that was welded May 8th. The sample waited for RT, lingered for annealing, waited for cutting, waited for machining, waited for tensile testing, and now it is ready to bend.
That's pretty quick in comparison to a procedure for NAVSEA that took nearly 2-years before it was approved for production.
