AWS makes no distinction of weld depth limitation/qualifications like other codes, so multiple welders performing welding on one joint is a gray area at best.
The weld would still technically be classified as a CJP, therefore I would say no, not allowable.
It would really come down to having a written procedure and having it approved by the Engineer of Record (EOR). If they agree with it, then its allowable.
