If you are talking about Deposition rate then, you need to be more specific. Why do I say this? There are certain variables necessary in order to accurately calculate deposition rates depending on what welding process is being used. Also, if the process being used is manual, semi-automatic, mechanized, robotic, etc.
The material and it's dimensions are also necessary in order to determine deposition rates. Diameter or dimension of filler material, how much energy is used, travel speed, etc. All of these variables, and sometimes other variables have to be considered in order to establish a formula in order to accurately calculate deposition rates. Even so, the deposition rate will only be as precise as the type, and amount of variables included in the formula.
As for references go, there are electrode manufacturer tables which give you "average" deposition rates
However, if you're talking about electrode consumption as it relates to "non-consumable" electrodes used in processes such as: GTAW, PAW, PAC or even resistance welding electrodes then, you are asking something different than "Electrode Consumption".
If you are asking how you can calculate what I just described then, many more variables have to be added to a formula in order to calculate roughly, the amount of electrode deterioration, contamination, and consumption! Precision is also elusive in this calculation without all of the variables included, and in order to have consistency in both calculations, one has to consider different fluctuations in the variables,
eg. enrgy input fluctuations, shielding/plasma gas fluctuations etc.
Only then can one produce a formula that can actually attempt to calculate "average electrode consumption".
I hope you can understand now that nobody here can give you a good answer to both of your questions without having any specifics about your application, process, energy input (joules or newtons), and other variables such as: thckness of material , filler metal type, thickness or diameter, joint design, dimensions, travel speed, etc.
Everybody that frequents this forum would be happy to help out in answering your question sir. Please do not misunderstand me when I mentioned that nobody here can give you a good answer to your questions.
If you would be so kind as to provide as much specific information as possible, then I'm sure we can help so, I look foward to reading more from you sir!
SSBN 727 Run Silent. Run Deep!!!
