Hi Gents,
I have 2 question regarding WPQT with PJP:
1) Does AWS D1.1 allow to perform qualification test with PJP groove plate?
2) How should i consider qualification range of thickness for T joint (one member is 40mm-welded side, bevel is PJP double V with 16mm penetration for one side) ;second one 60mm)
Many Thanks
