On a 36” pipeline, replacing a section 200 feet long. Cold cut & remove the old section, drop in the new section which is a bit longer than necessary, do one weld, then how exactly is the other end measured?
With a sideboom, overlap the new section on one side of the old pipe, make a mark.
Swing it over to the other side, make a mark.
Put it on top of the old pipe, make a mark.
Then take the shortest of those marks and that’s the final cut?
Or am I way off base here?
