Up Topic Welding Industry / General Welding Discussion / Tensile Test ( ISO 4136)
- - By zeki.kasap (*) Date 11-18-2019 05:41
Hey everybody,
Anyone knows the reason why we use radius for solid section ? Solid section seems like a bullet. I accually prefer to do without radius, if any good reason does not exist.
Thanks for your all respond.
Best Regards.
Parent - By 803056 (*****) Date 11-18-2019 14:08
Sorry, I don't understand the question.
Parent - - By Are Aye (*) Date 11-19-2019 10:51
Zeki.kasap,
Are you referring to Radius of Fillet on machined section (Tension-reduced section)?
Are Aye
Parent - - By zeki.kasap (*) Date 11-25-2019 11:49
Yeah, that is what I mentioned about.
Any information do you have the reason whywe use like that ?
Parent - - By Jim Hughes (***) Date 11-25-2019 17:57
zeki.kasap,
Just keying off your signature line. I don't feel like I completely understand your question.
Parent - By OldMan Date 11-28-2019 20:37
The fillet curvature is there to reduce stress concentrations. However the reason you do not use a simple specimen with the same diameter throughout is because you want failure to occur at the reduced section (preferably in the middle) and not at the ends of specimens located in the grips.
Parent - By Are Aye (*) Date 11-26-2019 08:38
zeki.kasap,
the design or geometry of reduced section (curve/radius) is to lessen or reduce the amount of stress concentration during testing.
the higher the stress concentrations are, the lower is the measured strength.
Are Aye
