If you must keep the above mentioned dimensions for your test (land, gap, bevel) I can suggest a couple of things.
Go to a full length 3/32 electrode minimally (preferably a water cooled torch)
Create a pointed tip, blunted at the end.
Assuming you have a foot pedal control, set the amperage at 150, you may need even more. Keep in mind you may also find it necessary to decrease your heat input and increase your travel speed as you proceed along your coupon, once your test piece gets good and hot the welding becomes easier.
Remove all oxides from front and back of weld zone (I prefer 1.5 inch 80 grit aluminum oxide discs on a 18,000 rpm. 90 degree pnumatic angle die grinder.)
Assuming your powersource is squarewave, and your material is well preped, set your balence control to 7or 8 on a scale of 10. (max penetration 10 vs. max cleaning 1)
Try keeping your torch angle close to 90 degrees rather than a more push style angle, with aluminum the heat goes right where the electrode is pointed, and if your having penetration problems than it should be down where you wish the melt to occur.
If however, you can change your land and gap conditions than you can do even more to gain your penetration, but I won't get into that unless those conditions are variable.
tell us how it goes
Lawrence
