I ran into a pattern that I'm not familiar with and want to run it by you guys.
The deck is a narrow low flute "NA" type deck and they are calling for 3/4" diameter puddles(arc spot) in a 24/8 pattern.
I've seen 24/6 before but the composite decking had a wider lower flute where you could place two puddles in the 2 middle low flutes to achieve the 24/6 pattern. This deck is too narrow, so do I make them place two puddles side by side(one on each of the joist top chord members)?
Edited the size of the attachment to 3" x 6" but it still looks huge on screen, moved the attachment to the last post and now it seems okay...wierd.
