Like Scott stated, thickness of material tested on is different for welder qualification for fillet welds.
AWS D1.1:2015
Clause 4.21.2 Fillet Welds for Non-Tubular Connections sends you to Table 4.11 where you will find the Fillet Weld Options and test plate thicknesses, specimen requirements and ranges of thicknesses qualified...etc You will probably use Figure 4.25 that gives you the specimen dimensions and locations from where they are to be cut from. Figure 4.4 shows test positions for fillet welds.
