I answered a bit quick, but you merely need to document that a representative of your company has witnessed them using the process sometime within the last six months. I know fabricators document this in various ways, but it all ends up the same as long as it is documented. Some use a traveler that follows a piece through the shop and the welder applies his/her time to that traveler and that is proof enough, some actually fill out a continuity record(that was what I always did), others use their time card system, bar code or whatever. It's nice when you spell out how you document this within your quality manual. That helps an auditor understand that your company is trying to show the continuity in some manner.
