wow! 4,000 lbs per day! how many spools can that be? I would be very proud and happy if i will have one welder who can burn that much on my team, even @25% of that rate. Is it really true? As far as I can recall, my welders can burn no more than 2 spools per day.
when you say 25% arc-on time, do you mean 25% x 10hr/day = 2.5 welding time in a day? what is he doing on the other 7.5 hours?
Cloud based data monitoring is new to me; can you enlighten me further on that? how much will it cost to have that?
I believe we don't have workstations, our welders work in a covered fabrication shop where structures are fitted up,assembled and welded in an open space inside the shop building. I' beginning to think that our shop is way too primitive than yours
Thanks for the new information/knowledge
