Hi Gents,
Could you advise, we have a 25mm (Vertical- T2) & 50mm (Horizontal-T1) "tee-joint" test coupon for Fillet Weld PQR .
How much should be our minimum leg length for this test coupon 19mm or???
(Code says: size of fillet weld (leg length) = T2 , not more than 19mm.)
