Hi AL,
The original Poster was using metric dimensions, I believe for joining 25mm to 50mm plate.
Using the thickness of the thinner part joined, T/2 = 12.5mm +1 = 13.5 mm ideal fillet weld size.
With Imperial dimensions replace 1 with 1/16", so 1" / 2 = 1/2" + 1/16" = 9/16" ideal fillet weld size.
Not perfect in all cases, just a rule of thumb.
Ref D1.1 -
