Dear Sir/Mam,
Can we use SAW filler wire (cut pieces) in place of GTAW filler wire if chemical is same, in case of GTAW welding process.
Is there any code restriction such as SFA specifications in WPS.
And, if it is the only option to use SAW wire can we recertify it as GTAW wire?
