If it meets the requirements of ASME Sec. II Part A. then you are golden. If other requirements are to be met you did not mention them, like the material needs to meet ASTM 923 A,B,C or any NACE requirements that are often associated with this material. Also what is the % Austenite and % Ferrite that is required? Depends on what kind of nasty chemical that the material could see.
