Al has the correct recommendation.
D1.6 2017 does not use the terms "demand critical" "protected zone" or the word "seismic" in code text.
So the Engineer is asking for some special consideration, which is up to him to define, since the code does not.
That special consideration is going to cost money, so be sure you make that your own "special consideration"
