David, Clause 6, particularly 6.1.4.2 may be helpful...
6.4 Essential Variables
6.4.1 Welding Procedure Essential Variables.
The Welding Procedure Specification (WPS) shall document all essential variables and supplementary essential variables, when required, as summarized in Tables 6.1 and 6.2. When a welding procedure includes multiple processes, the WPS shall include essential variables applicable to each process.
When multiple processes are used for qualification of a single welding procedure, they may be used individually, but only within the qualification and thickness limits of Tables 6.1, 6.2 (when applicable), and 6.3 for that process.
6.4.1.1 Changes to Essential Variables. Any change to an essential variable beyond the limits set forth in Table 6.1, Table 6.2, or Table 6.3, as applicable, shall require qualification of a new or revised welding procedure.
6.4.1.2 Welding Procedures with Multiple Processes. When a welding procedure has been qualified using multiple processes to produce a single test weld, separate WPSs for each process may be created for each process. Essential variable limits of Tables 6.1 and 6.2, as applicable, and thickness limits of Table 6.3, shall apply for each process individually.
(1) When qualifying a WPS involving multiple welding processes to be deposited in a single joint, the approximate thickness of the deposited weld metal from each process and for each set of essential variables, and supplemental essential variables when applicable, shall be recorded on the supporting PQR.
(2) The tension, bend, notch toughness, and any other mechanical test specimens shall include weld metal from each welding process and combination of essential variables, and supplemental essential variables when applicable.
