To both Jeff and brande
very good advice in using a vapor-degreaser.
However, I noticed that both of you have been concentrating on the cleaning of the base material which is good but, "does'nt cover all of the bases" so to speak.
It's just as important to also clean the the filler rods prior to welding.
If the filler rods have been out of their protective plastic seal for awhile, and have'nt been cleaned prior to welding then, the chances for the filler rod to become contaminated have increased. Surface oxides may have also formed when exposed for a prolonged period to the atmosphere, and increased humidity can also cause further contamination. Acetone or Xylol will work as you mentioned before.
Just make sure that you use a non-lint forming, non-abrasive material when you wipe the filler rods immediately before welding.
Another area that you might want to look at is the amount of moisture that can sometimes be found in the shielding gas because, the porosity may come from the increased amount of moisture in the gas cylinder or a leak in the regulator/flowmeter or conections that are'nt properly tightened. Even the gas solenoid in the machine may be a source of increased moisture in the shielding gas especially if it's location is in close proximity to the water/coolant solenoid which could transfer some of it's own condensation to the gas solenoid. this is highly unlikely but you want to "cover all of the bases". Also check the gas lines, torch connections, and if there is any type of moisture barrier between the gas, and coolant line inside the torch. condensation transfer may also be a cause here. One other possibility is that you could probably use a gas diffuser on your GTAW torch in order to shield the weld zone better.
In other words start by eliminating all of the possibilities!
To Jeff,
If you could tell me a little bit more on how thick the material is, the joint design, and the method (DCEN, DCEP, AC(HF)), and the type of tungsten you are using to GTAW the Aluminum. I then could give you some more suggestions that could help eliminate the problem you are encountering. Brande might also give you some more suggestions if there is more information provided. No offense brande!
Finally, you may want to check the amount of cfh you're using for your shielding gas, because not enough shielding gas in itself can be the cause of porosity. Even if the shielding gas is as pure as you can get, if there is enough moisture in the atmosphere then, it can easily mix itself with the shielding gas even if the flow rate is adequate or not. If you need onsite help, you may want to call your welding supplier, and ask them to help troubleshoot the problem if it still exists. If the supplier does'nt feel that they're responsible in helping you out then, get one that will!!!
A serious and complete audit regarding all aspects of the procedure being used is necessary in order to eliminate the problem. Please let me and others know what you find as the cause
SSBN727 Run Silent... Run Deep!!!
