Happy weekend to all,
Came across a case recently when it was told that “ weld repair of flange is not allow” but the flange in question is purely for the purpose of structural connection between sections not mainly for shearing load with no pressure retaining or sealing purpose.
Weld build-up is common to restore pressure vessel base metal with qualified procedure and for flanges of pressure piping there may be concerns about weld repair of flange sealing surfaces making the weld repair not allowed. But this is a structural flange in question.
Nobody is telling why and the only reason is the spec. says so. It is doubted that some wording of technical requirement is indiscriminately quoted across different industries merely because something such as “flange” is sharing a same term or name.
Can anyone on the forum share any deeper insights specifically in the expertise of structural design, fabrication practices, and/or experiences for the specific topic?
Cheers,
JZ
