Up Topic AWS.org / Forum News & Help / RMD Miller Technology MILLER with Dioxide Carbon SG
- - By MIGUEL TERAN (*) Date 11-15-2021 19:58
Hello friends and dear colleagues:
Anyone  has had experience welding with RMD Technology MILLER and shielding gas Dioxide Carbon at root pass ? It´s possible at theory ; but how effective can be . Thankful for your advices.
Best Regards
Miguel Teran
Parent - By 803056 (*****) Date 11-16-2021 02:26
We qualified WPS for carbon and low alloy steel using 90%Ar with 10%CO2 per Miller's recommendations. We did not use 100% CO2.
Parent - By Lawrence (*****) Date 11-17-2021 14:03 Edited 11-17-2021 14:08
Miller Says Yes
https://www.weldersupply.com/Content/files/PipeWorxRemoteFeeder%20-%20Copy%201.pdf
How effective depends on what you are welding eh?
How will you accomplish fill and cap passes ?    With Co2 you will not get a spray transfer.    Will you switch to FCAW for everything but the root?
How the C02 performs on the root will also have a lot to do with the base metal type, if impacts are required and more.
I suppose a dual feeder GMAW setup with solid wire on one side and FCAW on the other could do a very good job on pipe... RMD for the roots and FCAW on the fill...... All with Co2 weld gas.    It's possible.
If you are in the "shopping stage"   I would just ask Miller to bring a RMD power supply into your shop and prove what it can do before you lay down the money.
