My questions are about using 92% Argon and 8% Carbon Dioxide shielding gas with Hobart’s FabCOR Edge E70C-6M electrode.
Here is the link to the data sheet:
https://www.hobartbrothers.com/wp-content/uploads/hobart-catalog/datasheets/FabCOR_Edge.pdfOn the data sheet, in the upper left corner, is the information:
AWS 5.18: E70C-6M H4
EN ISO 17632-A T46 3 M M21 3 H5
First set of questions:
I am assuming that the M21 means that this electrode is only approved for M21 gas under AWS A5.36, which per AWS D1.1 (2020) Annex M Table M.5 is a mixed gas with greater than 15% up to and including 25% CO2. Is this a correct assumption?
If my assumption is correct, why does Hobart bother listing mechanical properties with 90/10 shielding gas (which would be M20)? And why would Hobart have a parameter table using 90/10 data and only mention 75/25 data in the notes below the table?
If the electrode is only approved for M21 gas, but I want to use M20 gas, would I have to qualify the WPS?
Or have I misunderstood what the M21 is for on the data sheet?
Second set of questions:
In Table M.1, it says that AWS A5.18 electrode with a classification of E70C-6 should be used with M21 gas but refers to note i below which says “
For purposes of the D1.1 code, the prequalified argon/CO2 mixed shielding gas shall be limited to SG-AC–20/25 as with the previous AWS A5.18 and AWS A5.20 classification shielding gas requirements, and not the shielding gas range of M21.”
Does this mean that when using E70C-6 electrode, the shielding gas should really be 20 to 25% CO2 and not the 15 to 25% of regular M21 gas?
If yes, then using 92/8 shielding gas would not allowed under A5.18 either. Is that correct?
All of this boils down to one question really: Would a WPS written to AWS D1.1 (2020) requirements using E70C-6 electrode and 92% Argon 8% Carbon Dioxide be considered prequalified?
