Have you met all the conditions of 7.9.1.2 (1) through (6)?
(5) The interruption would be where the ends of the backing have not been welded together. A gap no more than 1/4-inch is permitted as long as it isn't in the corner.
(6) The interruption can not be located in a corner. If the backing bar is welded with a CJP groove weld, it isn't discontinuous.
My take is that the CJP groove weld can be located in the corner of the hollow structural shape.
Just remember, "He who holds the gold gets to make the rules." You can always go to the Owners Representative, i.e., the Engineer, for clarification. The Engineer has the authority to add to, delete, or modify the Code. He makes the final determination if you are at loggerheads with the Verification Inspector.
