Hi Jim,
Thanks for adding the ideas.
I have to point out from my years of exp working with US based companies that in boiler industry using 300 series SS in superheater or reheater will call for joining these ss tubes inevitably to ferritc nozzles of header pipes of especially Gr.91 materials.
And it was EPRI trying to develop a filler metal EPRI P87 for this application.
Check this out:
https://www.epri.com/research/products/000000000001019786If you mean P No.1 by P1 for A106 I agree that it is not recommended to be joined with Gr.91. A good design will not make such a decision to make these two material meet. It will either make A106 in a wrong service condition (too high temperature) or spend too much money in using Gr.91 where a lower grade could be sufficient.
