Up Topic AWS.org / Forum News & Help / Hardox to Hardox Welding with SS filler material
- - By MIGUEL TERAN (*) Date 03-29-2023 17:00
Hello Dear colleagues,
As per welding Handbook Hardox ,they  say that, when  using SS filler material , preheating can be avoided, as opposed to using los alloy steel filler materials.What is the technical reason that explains that advice ?
Thanks for your support.
Parent - - By Jim Hughes (***) Date 04-06-2023 11:07
Its their material. You would have to ask them. What is the Hardox material you are welding? How thick is it?
Parent - By MIGUEL TERAN (*) Date 04-10-2023 03:59
Of course ...... Hardox 450 ,   from 1/2" inch to 1" inch Thickness.  FCAW process
Thanks a lot of
Parent - By lczhouheng Date 04-02-2024 05:08
G 18 8 Mn is proposed according to Hardox handbook.
