Hello everyone,
Concerning Intermittent staggered welds, It's understood that the welds start on the arrow side but I'm unclear as to what is acceptable to the placement of the first weld on the other side. Effectively, can the weld start at the end of the arrow side weld? or does it need to be in-between the 2 welds (arrow side) evenly placed?
https://awo.aws.org/2015/09/mis-understanding-welding-symbols-part-2/Aws explains the misconceptions but does not indicate the start of the weld on the opposite side. using the photo showing the staggered welds, the first weld is placed on the rightmost side and has a length of 6" on the opposite side of the joint can the weld be started 6" from the right side? or must it be placed directly in the middle of the welds (like in the image) can the placement be like in the capture2 image?
I can't find any reference in the AWS D1.1:2020 code book that explains this
