Sometimes it helps to look at issues from a business sense.
First, 0 tolerance for laminated plate in cyclic connections, period.
Raw, uncut plate lamination scan inspections of materials to be used in cyclic connections make sense as an investment in scrap reduction. Meaning, if a lam scan is part of the receiving process, rejectable plates can be returned to the vendor without charge, as long as the material has not been cut or damaged by the receiver.
When a plate does make it through to being cut before a lamination is detected, 0 tolerance means scrap the plate or at least laminated sections of the plate, so that material investment is lost.
When it comes to 100% undoubted static connections, reality is that lamination is not really a problem, even though most weld codes will call for rejection. Any code restriction can be over ridden by the Responsible Technical Authority, most often the Design Engineer over the project. This carries a lot of risk for the signers of the necessary documentation, and may also require approval from the Customer's and/or End User's Engineer, so it's not often done.
However, it does make business sense to use already purchased materials somewhere, rather than scrap, if it can be properly controlled. One way is to use it for temporary construction aids that shall not be included in salable product. Another way is to approve it's use for guaranteed static connections. Also, it can be used for weld training purposes.
I guess the point is 0 tolerance for cyclic connections shouldn't have to mean 100% scrap of laminated materials.
Tim
