Hello John!
I like the concept very much John because, of the fact that you have more control in not only customzing your mixes but, also being able to eliminate or minimize the potential for the gases to separate or stratify!!!
These systems are cost efficient for companies that use alot of mixed gases when welding in the long run, and not recommended for smaller shops that generally use a variety of different processes but, in proportion, do'nt use as much mixed gases when they're welding as you already know... Besides, the initial investment probably would set them back a bit, and there ROI (return on investment) would be long in coming back to the small shops, if any!!!
Both of the brands sound good to me especially the built in gas analyzer with alarm... The only thing I'm worried about is what do I do when the mix is'nt correct, and the alarm goes off!!! Do I stop welding or does the system have a separate proportional mixing tank whereby the gas that's been already mixed has enough in there until the rest of the system compensates for this condition. Correct me if I'm mistaken!
The fixed ratio on some of the models by Thermco would become troublesome on some of the models used for welding with shielding gases that require tri-mixes but, I think the model 6105 could work for those type of gases. I'll let you know more when I get some better understanding of how these systems are configured, so that I can make a better assesment when comparing the two brands and their models...
SSBN727 Run Silent... Run Deep!!!
