Dears,
Kindly advice, what will be the minimum base metal thickness qualified for prequalified Fillet weld WPS as per AWS D1.1. In the table under T joint says only less than 75mm and above 75 mm conditions. Not mentioned , what is the minimum thickness. Kindly guide me.
Thanks and regards,
Ganesh R Nair
