By -
Date 08-15-2000 14:42
What process will you use? For arc welding you can use a low-hydrogen
rod but a pre heat and post heat is a must. Austenitic stainless steel
or a nickel-based filler metals like E309, E312, or ENiCrFe-3 also may
be used. Any futher questions call MG Welding Hotline 800-558-8524
