That is a great question. I'll keep posted and see what replies you get to your question.
Thanks for asking,
John Wright
Thanks John for the response, I work for a custom pump company and we have castings that are not always the normal composition. One example is CW-2M material that is in the Hastelloy family. I had never heard of this material, eventually I found a match but I would like to spend less time finding this information.
C-Spec has a program that may be of help as far as looking up material types. It doesn;t select a filler metal but I beleive the search capabilities on the database may be of help.
A sample can be viewed at http://pnumbers.com/
I also have a page that allows the user to select a material type or grade and then view al resulting materials. This can be viewed at http://www.weldinginspectionsvcs.com/type_or_grade.asp . I haven't put the alloy materials in my database yet so your material is probably not in there yet.
C-Spec has a great deal of information in their software packages so they may be a place to start.
Have a nice day
Gerald Austin
Mr. Butler,
I like the ASM Handbook Vol. 6 (welding, brazing, soldering) for material identification and filler matching. It has good indexing and information on technique and behavior that would suit anybody from hobbiest to a mettelurgist
You could probably test drive one at your local library to see if it fits your need. They are a bit costly. Also I believe they can be purchased in CD form.
Lawrence, that's the one I use.
Mike Sherman
Thanks Lawrence for the information, I will check it out.
Ron B
Interestingly, this question came up at work today, then I read this post.
You might try to contact a testing lab. I was told by a lab I deal with (Dirats, in Massachusetts) that their equipment has software that will give the probable alloy based on chemical content. It only matches to known alloys listed by UNS, ASTM, or similar so if you have a proprietary alloy (as we did) you might not get a listing. I don't know if they or another lab can help but it might be worth asking.
Chet Guilford
