Hey TexasWeld!
I agree with John!!! That must be a "typo" in the spec because, the AWS electrode classification system has E8010 and E8011 listed but none where the second digit is anythihg other than the number zero after the first digit!!!
Lets break it down: according to AWS A5.1-91 and A5.5-81, classifications of mild and low alloy steel electrodes are based on an "E" prefix and a four or five-digit number. The first two digits (or three, in a five-digit number) indicate the minimum required tensile strength in thousands of pounds per square inch. For example: 70 = 70,000 psi,
80 = 80,000 psi. The next to the last digit indicates the welding position in which the electrode is capable of making satisfactory welds:
1 = all positions (flat, horizontal, vertical, and overhead), 2 = flat position and horizontal fillets. The last 2 digits indicate the type of current to be used and the type of covering on the electrode.
The "A1" suffix indicates the approximate alloy in the weld deposit:
(0.5% Mo).
AWS A5.5-81 Tensile strength, Yield strength, and Elongation Requirements for All-Welded-Metal Tension Test show values for those (E-8010-X and E-7011-A1) electrode classifications in specimens tested in the stress relieved condition. This is crucial in answering your question
because,with the E7011, your minimum tensile strength is less than with the E-8010, so is the yield strength, and the elongation is less with the E-8010 than that of the E-7011. I would definitely point that out to your vendor!!! C.Y.O (Cover Your Ass) Always!!!
If you have Lincoln Electric's "The Procedure Handbook of Arc Welding", you'll see the above written information in section 4 (Arc welding consumables) in pgs. 4.1-1 and 4.1-5 , tables 4-1, 4-2, and 4-7 respectively.
Hope this will help...
SSBN727 Run Silent... Run Deep!!!
P.S. NEVER ASS-out-of-U-and ME ANYTHING regarding Specifications!!!
