Don't know for sure-I'll go out on a limb here, but these two metals, on their own, are not metallurgically compatible, as far as I know.
The only way I can see you getting a joint with good integrity would be to plate the aluminum with copper and treat it as any other copper/copper joint.
There are some "super solder/braze materials available from the "snake oil " guys. Some live up to advertising, some do not.
A search of MG, Eutectic, Kapp Alloys, Hi-Alloy, Inweld, Nassau, Dytron and similar companies may give you what you need.
Let us know how you make out!!
Good Luck
brande
