Plasma welding process is quite similar to tig welding....basically the same process, although the arc is more controlled which allows thinner materials to be welded more efficiently. you will notice that the arc plasma is narrower and finer than with conventional tig.. the hardest part about plasma welding, is machine set up. your best bet to find out this information, is the people that sold it to you, or the manufacturer of the equipment.
