Up Topic Welding Industry / General Welding Discussion / Pinout required for SAF prestotig 200
- - By UKmxer (*) Date 08-14-2003 18:43
Does someone have details of the pedal port pinout for the SAF Prestotig 200 or a pedal with the potentiometer size and wiring.
I want to make a pedal for my unit.
Thanks
Parent - - By billvanderhoof (****) Date 08-18-2003 06:28
http://www.saf-wp.co.uk/
This is them in England. I assume from your "handle" that that's where you are. From there you should be able to get a service manual or the location of a dealer who might let you look at one.
Good luck-
Bill
Parent - By UKmxer (*) Date 08-22-2003 17:31
Hi Bill
Thanks for your help. I have contacted them and they say I have to go through one of their service centres.
I will have to keep trying, thanks once again.
Neil
