Isn't the P-number already listed on the qualified welding procedure you had to use for welder qualification? You can't qualify someone without a welding procedure.
But, if you just can't find your copy of the WPS or look it up in the qualification code, you might look up the P-number or S-number at http://www.pnumbers.com courtesy of C-Spec. They don't list an ASME IX P-number for grade 105-85, just grade 90-60.
Marty
