Up Topic Welding Industry / General Welding Discussion / Alum. Welding - Boiler Code Shop
- - By mktarby Date 08-19-2003 19:31
I'm looking for a certified ASME Boiler Code Shop that can weld Aluminum.
We are looking to manufacture a cast aluminum shell in multiple sections and need them welded and "stamped" to Boiler Code.
Thanks in advance.
Mark
Parent - By TimGary (****) Date 08-19-2003 19:57
MECO
Mechanical Equipment Company, Inc
3855 France Road
New Orleans, LA 70126
504-599-4000-main line
ASME/ISO/MIL-SPEC Vessel/Bolier Manufacturer
A+++ Quality! All Materials
Engineering/Fabrication/Installation
Good Hunting!
Tim Gary
Parent - By ssbn727 (*****) Date 08-20-2003 04:23
Welcome mktarby!!!
ASME Intl. has got a webpage that lets you search for companies that perform the code work you're looking for... Here's the page:
http://cstools.asme.org/holdersearch/index.cfm
Do a search on all certificates or any of the ones listed, and in whatever state or city you're looking for, then you'll be directed to a list of companies from all over the planet that holds certificates to perform Boiler/Pressure Vessel code work according to ASME...
You click on a company from the list, then wait for a smaller window to appear, and inside will be the company's address, what certificates they have but, not much else though... Good luck, and I hope this helps!!!
SSBN727 Run Silent... Run Deep!!!
