Charles, thanks for your input, your correct about the pwht,and it`s being done this morning per asme b31.3 per table 331.1 ,it shall have a hardness test after completion of pwht per 331.1.7(a), it also shall be radiographed per 341.3.1 (a) after completion of pwht requirements are met....I 100% agree, the welds should have been cut out and rewelded properly with ER502 but my power is limited to only bringing a problem such as this one to the attention of all parties involved and give my recomendation for actions to be taken to fix the problem and in this case I clearly recomended cutting out the welds and rewelding them properly of couse....I really hope nothing bad happens such as a melt down of those 8 heaters that are all built side by side and or if someone is injured as a result of this mistake, but if it does, man oh man ,heads are going to roll !!!! ( but it won`t be mine). But still that won`t help the fact that if someone is injured I will have to live with that the rest of my life, just knowing I was involved. INSPECTION IS FUN ISNT IT!!! ....Thanks again.
