Crisi, I feel the same way about it and that is the main reason for my post. There are so many new methods out there and I like to keep up with them as much as I can. When you are using UT for dissimilar metals, in this case ss cladding over carbon steel you have two different velocities to deal with. This is not a problem, you simply calibrate to the ss and take your thickness reading from the second pip on the screen that shows up because of the different velocity. The eddy current method requires a mock up of the required thickness of the cladding and shell to calbrate but is very accurate. Thanks and have a good one!
