Notes in the tail of the welding symbol are supplementary information. It looks like "PIT/300" is the WPS number the original fabricator welded with. Many DOT customers required that the WPS numbers be on the drawings before they would approve them.
If you are fabricating per that drawing, I would ask whoever supplied them if there is any significance that they know of, just in case that guess is wrong.
Chet Guilford
