Hello Kawika!!!
Welcome!!!
I don't know if this will help but, I had a liver transplant on 10/08/97
(Wow!!! it's going to be SIX years this coming Wednesday!!!)...
After about a year or so in my recovery, I went back to school to see if I could still weld. I quickly found out that I still had what it takes, so to speak...
I also noticed that I had this tremor or uncontrollable "shakiness" in my hand that was'nt there prior to my transplant, in fact the tremor was in both hands!!!
I spoke to a physical therapist to get some ideas on how I could reduce the "shakiness in my hands". The therapist suggested to relax, get comfortable with your position with respect to the weld area or joint position, control your breathing better, and to find some sort of support for my wrists that would minimize the localized tremor I was experiencing as a result of being on steroids and anti-rejection medicine (Prograf) which I must take for the rest of my life until the experts can come up with something better...
So, after trying a number of cumbersome support devices designed for carpal-tunnel syndrome, and not getting the results I was looking for, I decided to try a regular pair of athletic wrist sweatbands, and lo & behold!!! The solution to my problem was found!!!
I know that this helps with other people that do not have the same condition as I did, and yet nonetheless - experience the " shakiness in my hands". I mean no disrespect when I say this...
I suggested this to some of my own students, and it seemed to work for them also... The reason behind this is the combination of support, flexability, and freedom of movement offered with the wristbands that was'nt found with any other support device...
In summary, I believe that some of the shakiness can be minimized by controlled breathing, and by finding a more relaxed, supportive position, and a relaxed state of mind.
However, if there is still some "shakiness" then, using the wrist sweatbands that are at least 2 inches wide will help you reduce it to the degree where it's no longer noticeable, and will improve your steadiness when welding... These days, I'm no longer on steroids, and take a lesser dose of the anti-rejection drug which has greatly reduced the amount of shakiness that I no longer use the wristbands when I'm welding, and yet without those wristbands, I could'nt think of giving a decent
demonstration for students back then!!!
I wish you the best of luck, and please let me and others know if any of my suggestions helps you out!!! Also, I'm sure other people in this forum will have some suggestions that may help... Just remember not to give up on trying whatever it takes to steady your hands while you're welding!!! Once you overcome this, your confidence level will increase when YOU notice that your welds improve!!!
Feel free to ask any other welding-related questions that you may have!!! The vast majority of us are here to help, and you'll find a wide variety of experience, knowledge, wisdom, and expertise here!!!
Best of all - it's FREE!!!
One of my most repeated words of advice to my students is: "Practice, Practice, Practice, and when you get so tired that you no longer want to continue, PRACTICE SOME MORE"!!! I also mention:
"Do'nt forget to breathe while you're practicing"...
Look foward to reading more from you soon!!!
SSBN727 Run Silent... Run Deep!!!
