Hi Tradingpaint!
When you mentioned 400 amp disconnects are you referring to cable disconnects? I say this because, that may be the problem...
You may be looking at a wire chart instead of looking for a welding cable chart... I'll get back to you later today so that I could steer you in the right direction... Of course, there are others here that will also be able to help so, talk to you later!!!
SSBN727 Run Silent... Run Deep!!!
