Up Topic American Welding Society Services / Certifications / ?? about Table 4.10 in D1.1
- - By jwright650 (*****) Date 10-29-2003 15:05
Question I have is about Table 4.10. Testing 6G on 6" Schedule 80 with backing. I'm looking at Table 4.10 Item (2) Tests on Pipe or Tubing, and it has a reference to Note #5. I go to the end of the Table and look at Note #5. It tells me "See Table 4.8 for appropriate groove details. This is obviously a mis-print or a mis-type. Table 4.8 is talking about Annex M and Unlisted Steels qualified by PQR.
Does anyone know which Table/Figure it should be referring to?
John Wright
Parent - - By jwright650 (*****) Date 10-29-2003 15:25
I think I may have figured out the answer to my question. Note#5 of Table 4.10 should be referencing Table 4.9. I looked at some of the previous versions of D1.1 and figured out they are talking about the Welding Positions Qualified by Plate, Pipe, and Box Tube tests. The 2000 code Table 4.10 Note #5 referenced Table 4.8 and that was correct in 2000, but I guess they forgot to change the reference when they changed the Table to Table 4.9 in 2002. Every time they change all these Figures,Tables and paragraphs around, it seems this happens. I don't see how they get it as accurate as they do with all the switching around going on.
John Wright
Parent - - By thcqci (***) Date 10-30-2003 15:15
You are correct about 4.9. See below my text from Errata for D1.1 2002:
Errata AWS D1.1/D1.1M:2002, Structural Welding Code—Steel
(updated 7/15/02 10:46 AM)
Page 17 - Section 2.23 .2.2 — incorrect reference to 2.23.6.6—change to 2.20.6.6
Page 49 - Figure 2.14 — For upper right hand corner box section detail, change lower “branch member” to “main member”
Page 63 - Table 3.1, Group II — For ASTM A 588 and A 606, change superscript “5” to “2.”
Page 65 - Table 3.2 — For ASTM A 36 in Group A and Group B (left column), delete 3/in. thickness limitations.
Page 66 - Table 3.2 — Under Group C (Welding Process), change “GTAW” to “FCAW”.
Page 67 - Table 3.3 — Delete superscript “3” next to SAW and GMAW
Page 72 - Note 3 for Figures 3.3 and 3.4— change “(see 2.27.5)” to “(see 2.17.2)” Page 72 - Note 9 for Figures 3.3 and 3.4— change “limitations of Note E” to “limitations of Note 6”
Page 135 - Table 4.5, Item 30— change “Table 4.7” to “Table 4.8”
Page 139 - Table 4.8 — Delete note “1” superscript after “PQR Base Metal” in first column header
Page 142 - Table 4.10, note 5 — change “See Table 4.8” to “See Table 4.9”
Page 192 - Section 5.27 — incorrect reference to 2.36.6.6(3) — change to 2.20.6.6(3)
Page 272 - Figure Ill-i — Lower right hand — change “C HAZ 2mm. . .“ to “C —HAZ1mm...”
Page 314 - CJ[P groove weld (tubular structures) definition — change “Figures 2.4” to “Figures 2.21”
Page 493 - Index — references for “End returns” are incorrect — change references to
2.3.2.1, 2.8.3.3
Page 502- Index —reference for “Yield line analysis” is incorrect—change reference “C2.40.2. 1” to “C2.24.2. 1”
Parent - By jwright650 (*****) Date 10-30-2003 17:39
Thanks for confirming my assumptions. After I had looked at several years worth of D1.1. I was convinced that they forgot to change the note from the previous year. Looks like they would try and keep the Tables, Figures and Paragraphs numbered the same year after year to avoid the confusion.
John Wright
