Hi TIG6al-4v!
Extra Low Interstitial or ELI refers to lowering the amount of interstitial solid solution -a solid solution in which the solute (stranger) atoms of Oxygen, Hydrogen, Aluminum and Iron occupy positions in the host space lattice and by becoming part of the lattice, which as a result, distorts the lattice so in effect, this is ERTi-5ELI is really a different grade of Titanium technically speaking of course and the AWS should clarify this because there are only two commercially available grades of Extra Low Interstitials Ti6AL-4V. they are grades 23 and 24 w/ru...
They should really call this ELI variant of Ti6AL-4V of filler, ERTi-23ELI because that's the grade number (23) of Ti that stands for an ELI variant of Ti6AL-4V!!! To add to the confusion, there is also a variant of
Ti6AL-4V Grade 23 ELI that has ruthenium which is: Ti 6AL-4V ELI 0.1 ru or Grade 29 Ti... (Ruthenium is a cheaper alternative to Palladium although it requires twice as much of this element to achieve the same corrosion resistance)
(AMS 4954) (AMS 4956)
(Ti6AL-4V Grade 5) (Ti6AL-4V Grade23 (ELI))
(Composition, percent) (Composition, percent)
Oxygen max - 0.25, 0.13
Hydrogen max - 0.015, 0.0125
Aluminum - 5.5 - 6.75, 5.5 - 6.5
Iron max - 0.40, 0.25
Other (unspecific)
elements (each) - 0.1, 0.01
I intentionally left out all of the other elements that make up both of these grades of Ti6AL-4V because they are identical in percentages except for of course, the remaining amount of Ti which makes up the majority element of these Ti alloys...
As you can see, the differences in the percentages of the above listed elements and other (unspecific) elements in these two grades of
Ti6AL-4V reveal as to where the interstitials ("stranger" atoms) may originate from.
If you minimze just a small amount of these interstitials, you then minimize distortion within the lattices, therefore encouraging stable and consistent grain stuctures in the welds which increases toughness, fatigue strength and corrosion resistance...
This also should answer your first question about the differences between the two Ti alloy grades. The only other differences between these two different grades of Ti6AL-4V are the mechanical properties referring to Ultimate and yield strengths in the the chart below...
The one value that stood out is the differences in MPa's for the yield strengths of each grade of Ti. I would think that maybe because of the lower amount of interstitials in the grade 23(ELI) would account for this.
Ultimate Strength Yield strength
Grade 5: 130/895 (ksi/MPa) 120/428 (ksi/MPa)
Grade 23 (ELI): 120/828 (ksi/MPa) 110/759 (ksi/MPa)
Now your last question is more complex but, I would say that because of the increased toughness, fatigue strength and corrosion resistance, there is sufficient justification to use the ELI variant so that you would minimize the formation of interstitials in the grain structures of the weld metal itself... Hence insuring weld integrety!!!
Btw, none of these grades are accepted for ASME code construction yet!!! However, Grade 9, another "alpha-beta" Ti alloy designated as:
Ti 3AL-2.5V is now permitted for division 1 code construction.
This higher strength alloy could be considered for solid construction of certain large, high temperature pressure vessels like autoclaves used for pressure hydrometallurgy, or for high pressure piping systems where it's properties could lead to economy as far as service life is concerned...
I hope that I was able to answer your questions regarding the use of these various grades of Ti6AL-4V!!!
SSBN727 Run Silent... Run Deep!!!
