Has anyone used a "Stainless Steel Back-up Flux" with their TIG welds? The Tin Man web site is selling it. I was wondering if it worked and what you thought of using a "Flux Paste" instead of back gassing the weld with argon.
Thanks in advanced,
James Nichols
Improve your MIG and TIG welds! Coat the reverse side of the material before you weld and this back-up flux will make the back side of your weld smooth & even with great penetration. Perfect for header and pipe work, better air flow.
The Tin Man URL Stainless Steel Back-up Flux:
http://www.tinmantech.com/html/stainless_steel_welding_suppli.html
The Tin Man Web Site:
