Hi Great falcon!
Just a thought so; You could convert the article into a .pdf file format then, post it as a webpage if possible... Once this is done, you can post the webpage address in this forum so that the other participants can view your article online... It would be also beneficial if you could provide us more specifics as to what your project entails like the purpose of the project, materials used, welding or joining processes used, fabrication methods or processes used, etc. I hope this helps!!!
SSBN727 Run Silent... Run Deep!!!
