Brazing for the most part is no different that Oxy/Fuel welding but not to be confused with Silver Solder.
Dull red will not do the job for steel, You want the filler to flow into the work not just lay on top.
Clean is a must, no rust or scale not to mention oil and dirt.
With precoated filler you need only to clean your work real good before heating. Do not preheat the filler rod
Powdered flux are much the same only you will need to heat your filler rod and dip it in the flux to coat it. Heat the end of the filler rod with your torch
Most paste flux can be put on before heating but after cleaning.
Most of the time you want a Neutral flame (sometimes Cast Iron requires more oxy). Torch size matters in conjunction to the cross section of the work and the filler.
If you are working thin sections you might try laying down one puddle at a time until you can follow the flow of your filler. Heat a spot to almost melting then add filler, back out and let it cool for a few seconds. Repeat that process over lapping roughly half of the last puddle.
Don't use a torch so big it will burn through your work before you can add filler. Use a torch that can apply enough heat to allow you to work at a confortable pace.
