Up Topic Welding Industry / Technical Discussions / Marquette M55796 Aluminum Arc Electrode
- - By greg1900dp Date 11-07-2003 01:25
Really have two questions: 1) How can I find this electrode, can I get in touch with a Marquette technical rep? No one seems to be able to help with this, and 2) This electrode is supposed to be a flux-covered self-shielding electrode, so can aluminum welding be done without gas?
Thanks for any help. Greg
Parent - By GRoberts (***) Date 11-07-2003 03:54
I have never used, but know that there are available aluminum sheilded metal arc welding rods (as in stick welding), but have also heard that their performance is poor and should only be used in emergency type situations. Things may have improved though. I found an online source that offers them at http://www.weldit.com/alum_01.html. Your local welding distributor should be able to get ahold of some too.
This web page advertized marquette electrodes
http://www.handsontools.com/store/list_products/?category_id=9842
If your main interest is welding aluminum without sheilding gas, it is also possible with oxy-fuel welding and brazing, but I haven't done that either.
Parent - By flatjwl (*) Date 11-08-2003 02:09
I have used the MARQUETTE electrode. It can be used with DCRP on reasonably thick material with some success. In the old days I carried some in the truck for emergency repairs of irrigation pipe.
As an aside, I found that it works best when used as a filler wire with the oxy/acet torch. This provides the option of joining thinner material. But neither the torch nor the electrode holder can match the TIG process for aluminum.
