Up Topic Welding Industry / Technical Discussions / Max. weld size
- - By vonash (**) Date 11-15-2003 00:13
What is the maximum size weld pass that can be made at the root of a groove weld? What is the max. size for subsequent passes?
Is this addressed in AWS D1.1; if so where? Please respond.
Vonash
Parent - - By pipewelder_1999 (****) Date 11-15-2003 02:05
If you are speaking of a Prequalified WPS see table 3.7 in the 98 edition. This indicates a "Maximum Root Pass Thickness" for SMAW, GMAW, and FCAW.
For a WPS qualified by testing a change in the number of passes by more than 25% for a given groove area would also require requalification.
I don't have my 2002 D1.1 handy so this may all be different now.
Hope that helps
Gerald Austin
http://www.weldinginspectionsvcs.com
Parent - - By vonash (**) Date 11-15-2003 14:33
Thank you Gerald. That is what I needed to know.
Vonash
Parent - - By jwright650 (*****) Date 11-15-2003 15:06
Gerald & Vonash,
The Table 3.7 still applies for the D1.1:2002 also. Paragraph 3.7.2 gives the width/depth pass limitation(Figure 3.1).
John Wright
Parent - By vonash (**) Date 11-22-2003 23:01
Thanks guys
