GOOD ADVICE EYE. I have witnessed, inspected and tested several welders while a building inspector in San Fransico. Also with 60 grade rebar make sure you use preheat if its cold or wet the bar will form martinsite when welded, a hard spot that usually will break under the required load when you tensile test for qualification samples.
