Up Topic Welding Industry / General Welding Discussion / Choosing the right welder
- - By 65 F-100 Date 12-10-2003 02:07
I am trying to weld a header for a 300 I6 that would accept a turbocharger. I know exactly how it will be designed but I need to purchase a welder to do it. The tubes are made from 2" schedule 40 piping. The flange will be about .5" thick. What welder would you guys recommend? I have seen similar setups welded with TIG. Is this necessary? I want the header to look very professional. How much would the welder cost me? What kind of rod or wire would I need? If I was to do it in stainless would this change things?
Thanks
Parent - By CHEVYTOWN13 (**) Date 12-10-2003 05:04
I can't help you on this one hometown. I just started the blues meself.
However, do you know about fordsix.com?
Place you gotsta be if you have an L6...
CT
